Multicolumn Listbox slow
Accepted by Tesla1977
This may or may not help, but might be worth investigating:
As you iterate through the cells, first check the current text color with a property read and only perform a property write if the desired color is different from the current color.  Reducing the number of property node writes may improve performance.
Message 11 of 12
(1,165 Views)
That was a very good idea. I tested that, and reading is much faster than writing.
Thank you.
Message 12 of 12
(1,146 Views)
