取消
显示结果
搜索替代
您的意思是:
Multicolumn Listbox slow
已解决!
转到解答
Recoloring cells in my multicolumn listbox is slow (1000 lines x 5-10 columns).
Yes, panel updates are already deferred. Problem is, that the users can add lines at the top of the listbox, and then every line below that has to recolor.
I will test the virtual MCLB that someone mentioned, but perhaps there is the option to change the indicator?
Is a table faster than a MCLB?
A line has only a single color, no need to color for every single cell.
0 项奖励
1 条消息(共 12 条)
5,386 次查看
Hi Tesla,
to increase speed you only need to color the lines visible to your user.
(I guess the user cannot see all 1000 lines at once?)
0 项奖励
2 条消息(共 12 条)
5,380 次查看
Thank you.
I already mentioned that I will try the virtual MCLB, but perhaps there is an easier way.
0 项奖励
3 条消息(共 12 条)
5,366 次查看
Hi Tesla,
I never heard of a "virtual MCLB" which "somebody mentioned".
Do you mind to provide links or example VIs?
0 项奖励
4 条消息(共 12 条)
5,363 次查看
0 项奖励
5 条消息(共 12 条)
5,360 次查看
Hi Tesla,
That VirtualMCLB is using the same approach of only coloring the cells visible to the user as I suggested before…
0 项奖励
6 条消息(共 12 条)
5,354 次查看
Yes, it is a possible solution, but perhaps there is an easier way.
That was the whole purpose of my post.
0 项奖励
7 条消息(共 12 条)
5,349 次查看
I was curious and tested the performance by myself. I think, this is good enough...
Greets, Dave
0 项奖励
8 条消息(共 12 条)
5,331 次查看
Thanks for your testing.
Just for clarifying:
My user adds a new line at the red position. Then I have to recolor every single line after that. And there are sometimes above 1000 lines.
0 项奖励
9 条消息(共 12 条)
5,320 次查看
Yes, after reading your first post more carefully I realized my misunderstanding. And now I see, you mean the Font-Color, not the cell (background) color. The performance of this is very poor, see my third testing- VI. I think, GerdW's suggestion is the right way- first recolor all visible lines, then all the others.
Greets, Dave
0 项奖励
10 条消息(共 12 条)
5,312 次查看
