Multi-line string -> Array?
I was wondering if someone could tell me how to take a multi-line
string and dump it into an array. I'm assuming that I use the 'Pick
Line' function in a while loop? What do I check for to terminate the
loop?
Thanks...
-- N
Message 1 of 8
(19,482 Views)
Attached is a sample vi.
*Note: There is a bug in the attached VI. This solution works only if your input string does not include any blank lines. This will stop after the first blank line.
[edited by moderator to add note 07/13-2015]
Message 2 of 8
(19,482 Views)
You could use spreadsheet string to array. Wire a line feed constant to the
delimiter input, an empty string array constant to the array type input, and
a %s to the format input.
Adam
"Natalia" wrote in message
news:99e216d.0210171408.22a87ca0@posting.google.com...
> loop?
> Thanks...
> -- N
Message 3 of 8
(19,482 Views)
In article <99e216d.0210171408.22a87ca0@posting.google.com>, "Natalia"
wrote:
> I was wondering if someone could tell me how to take a multi-line string
> and dump it into an array. I'm assuming that I use the 'Pick Line'
> function in a while loop? What do I check for to terminate the loop?
> Thanks...
> -- N
Natalia,
Use the 'Spreadsheet String to Array' vi. Use the End of Line delimiter
(or carriage return, depends on OS). Add a %s to the format string and
POOF!, an instant text array. No loops required. Oh yeah, you also need
to add an array string constant to the array type so the output comes out
as a string type instead of the default double.
You can do it with you present method if you need the loops for other
stuff.
To terminate the loop just look for a -1 in the output of 'Pick
Line' when searching for you CR or EOL. You just have to remember to dump
the last value.
good luck,
- Kevin
Message 4 of 8
(19,482 Views)
"kevin" wrote in message news:...
> > Thanks...
> > -- N
> Natalia,
t
> stuff. To terminate the loop just look for a -1 in the output of 'Pick
> the last value.
> good luck,
> - Kevin
Kevin -
Thank you. That did the trick.
-- Natalia
Message 5 of 8
(19,482 Views)
Message 6 of 8
(7,370 Views)
Hi siddesh,
welcome to the LabVIEW forum!
What's your point to add an image of a possible solution to a 19+ years old thread?
Why don't you attach the VI or atleast a snippet?
Why did you implement a more complicated solution than needed?
Why don't you follow those suggestions to use SpreadsheetStringToArray? No need to use a loop and an autoindexing tunnel for this purpose…
More simple:
(This is a snippet, which shows an image, but still contains the code!)
Message 7 of 8
(7,366 Views)
@siddesh_yadav wrote:
This also assumes array elements are not empty. It stops at the first empty element...
Typically, any manual solution is orders of magnitude slower then Spreadsheet String To Array.
Message 8 of 8
(7,327 Views)
