01-03-2011 02:56 AM
I've a project at my university that have to get the acquisition frame rate at 100fps with 3 cameras at the same time.
At first I use Vision module to get acquisition .avi file on single camera and it works fine.
I use grab method with IMAQDX to acquisition picture.
It can reach 100fps without any problems (resolution of picture is 640 X 480).
Then I start to use 2 cameras. It's seem like frame rate a little unstable but I can accept with this situation.
Finally I get to my goal at 3 cameras at the same time. The problem occur in this state.
Frame rate drop down around 50fps. Even if I try to reduce resolution to 320 X 240 it can just reach around 70 fps.
I don't have a clue about root cause of this problem. Could you please give me some suggestion to solve this problem.
My computer spec is :
CPU : Intel Core I5 2.7 Ghz
Ram : 4GB
OS : Windows 7 64 bit
Camera : all 3 cameras as you see in attach file interface with GigE card.
Sorry for my poor english.
Thank you for your help.
01-03-2011 07:27 AM
Do you have 3 seperate gigE ports or are you using a switch?
what is your architecture, do you have seperate loops, are you processing or displaying the images in this loop?
is the camera 8-bit or color?
You can start with a bandwidth calculation - 640*480*100*8 = 245 Mbits (adduming 8-bit cameras) and GigE doenst get the full 1000MB, there is always packet overhead. you might do best with a 4port card but its too early in the morning for me to think this out fully.
