More point for IV curve
I I'm having a IV curve their points are max 20 and I wanted to expand the points in more than 20 points, having same curve.Can someone please help me with that. I wanted a fine curve.
Message 1 of 26
(6,066 Views)
Could you post what you have?
Message 2 of 26
(6,030 Views)
You cannot expand points unless you have a theory about the shape of the function at locations where you don't have data, i.e. at the points you currently have (extrapolation, interpolation).
To just get a smooth curve you can use spline interpolation or a polynomial fit. If you have a theoretical model, you can use nonlinear fit.
Of you could just re-measure your curve using more points. 😄
(Is there a reason you tagged your question with "excel"? What does excel have to do with any of this? I assume you are looking for a LabVIEW solution, right?)
Message 3 of 26
(6,010 Views)
Message 4 of 26
(5,985 Views)
Yes sir, I can do fine curve in max 20 points, but I wanted a easy way to get more than 20 points with the same curve and the value so my R will go in smooth form. If I do that in 20 my R varies in zig zag form like it goes up and back to the curve.
Thank you
Message 5 of 26
(5,982 Views)
You either need to find another way of generating these points (you might tell us how you do that so we can help), or you need a way to interpolate between those points.
This interpolation can be don in a lot of ways: linear, quadratic, polynomial, spline, etc. interpolation. And you can also do this with FIR filters, curve fitting and I'm sure there are other ways.
Without knowing the background, it's a very open question.
Message 6 of 26
(5,966 Views)
What do you want me to show you?
Message 7 of 26
(5,960 Views)
Where do these points come from? If you want "in between points" the source of these points might be a good (the best) source. Everything else is basically fake.
From HW: sample at a higher rate.
From user: ask for more points.
From algorithm: configure it to use more points.
Message 8 of 26
(5,956 Views)
The points doesn't comes from anywhere I'm giving them to graph from as array.
Message 9 of 26
(5,953 Views)
So you want to expand 20 points that come from nowhere to more then 20 points?
Maybe you could post what you have...
Message 10 of 26
(5,949 Views)
