‎05-20-2009 08:38 AM
Hi all,
I have one installer of my application built through LabVIEW. I need to monitor the files like *.dll and other files which are installed on the system.
Can we get a list of files installed by the installer on the system for monitoring purposes?
Thanks.
-Parag D
‎05-21-2009 12:58 AM
Could anyone please let me know if this is possible in LabVIEW built Installer?
‎05-21-2009 02:46 AM
Hey Parag,
I'm not sure if this is exaclty what you are looking for, but you could try Process Monitor. Its a utility by Microsoft which provides a lot of info about the programs running on
your PC. Maybe you will be able to get the details from there.
‎05-21-2009 02:49 AM
WellWell, Its like I need to see exactly which files are going where during installation. This feature is available in many installers showing path of files being installed (for eg. Winamp setup).
‎05-25-2009 01:44 AM
Is there any other option available except process monitor? Process Monitor would just show the presently running background processes.
‎05-25-2009 03:42 AM
I think I understood your query correctly.
It is not possible with the labVIEw installer. You need to write it of your own using Install Shield package or something like that...
‎05-25-2009 04:44 AM
Hi Partha,
Can you please explain how to create a InstallShield package for LabVIEW Applications?
‎05-25-2009 05:09 AM
‎05-25-2009 08:51 AM
Well, I believe that LabVIEW Application Installer cannot be created through Installshield. Pls correct me if I am wrong
‎05-25-2009 09:02 AM
