12-06-2018 02:26 AM
Hi all,
I'm working with CompactRIO 9045. This plc is equipped with the rs232 and the rs485. I need to communicate with two devices in Modbus RTU.
I have no problems with RS485 communication. This is initialization VI:
I do the same operation with rs232 port (ASRL1::INSTR):
But I have this error:
Error -1073807246 occurred at Property Node (arg 1) in SubVIs.lvlib:Serial Shared Components.lvlib:Configure Serial Port.vi->SubVIs.lvlib:Serial Master.lvclass:Initialize Master.vi->Modbus Master.lvclass:Initialize.vi->Modbus Master.lvclass:Create Master Instance (Serial).vi->readExdSh1.vi
Possible reason(s):
VISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
The resource can't be occupied...
I have seen all national guides and tutorial, but I don't find the solution.
Can you help me?
Thank you.
12-06-2018 07:58 AM
That error usually means some other program has the serial port open. Once it in a while it might be an early instance of LabVIEW that opened it, but didn't close it cleanly. In that case, closing LabVIEW and re-opening will solve the problem.
12-06-2018 08:18 AM
Hi Revens,
I have dove it but I have problem again. I create a project with only VI and I have problem.
I think that there is a default process that occupies the rs232 port.
12-06-2018 08:50 AM
You'll need to figure out what that default process might be.
A common error is for someone to open up the manufacturer's software for communicating with the device, and failing to close it out before using LabVIEW to communicate with it.
12-06-2018 09:05 AM
Hi Ravens,
thank you for reply.
I haven't active process or application. I don't insert cable. I want see that I have an available com port.
12-17-2018 08:05 AM
you can find the possible causes as well as the solutions to the specified error in the following document:
Error -1073807246 Using NI-VISA
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NeQSAU&l=it-IT
Alessia
