Mitutoyo USB Interface
Thank you for your help.
I found the problem! In a mituotyo parameters, there are 2 output mode SPC and RS232.
If I choose RS232 mode and I write GA00\r, the respons is 911
If I choose SPC mode  and I write GA00\r, the respons is 01A+0000.032 when on the mitotuyo screen the value is 0.032 mm!
I don't understand why I must to be in SPC mode to communicate...
Now I will try to extract only the value in millimeter of the read buffer
Message 21 of 36
(4,051 Views)
Hi Rico, I have the exact same input tool and I cannot get it to communicate at all. I'm new at Labview but I've been looking over several different examples. If you got this to work, I'd appreciate your help.
Message 22 of 36
(3,782 Views)
Try this vi.
Message 23 of 36
(3,768 Views)
I need to configure for a USB RAW input and for some reason I'm getting an error in NI MAX "VISA (Hex0xBFFF003E) Could not perform operation because of I/O error"
Message 24 of 36
(3,756 Views)
Have you installed the drivers?
http://www.mitutoyo.eu/en_us/downloads/software-and-updates/
I'm not English, why do you speak of RAW? for me, it's picture format.
for the USB parameter, I have that:
9600 bauds, 8 bits, none, 2 bits Stop
but you can change it directly on mitutoyo.
Message 25 of 36
(3,751 Views)
According to Mitutoyo, drivers are provided since this is an Human Interface Devise.
Message 26 of 36
(3,736 Views)
One last question, did you use an input tool with your project, like the IT-016U? Or just the dial indicator directly to the computer.
Message 27 of 36
(3,716 Views)
No, I didn't use IT-016U or the dial indicator.
I have this DMX-1 USB between the pc and mitutoyo.
http://mitutoyo.incony.de/web/mitutoyo/en_GB/mitutoyo/01.01.053/DMX-1%20USB/index.xhtml
Message 28 of 36
(3,703 Views)
Thank very much Joan!!! I spoke to the Mitutoyo reps and no one mentioned the DMX-1. I appreciate all your help.
Gracias,
Message 29 of 36
(3,678 Views)
I was looking around and Mitutoyo doesn't sell this product in the United States. 😞
Message 30 of 36
(3,670 Views)
