Memory leak
It is an Aerotech motion system.
Message 11 of 15
(843 Views)
I'm impressed. Last time I looke dtheir stuff was slick. Airbearing rated for unlimted cycles...
Ben
Spoiler
Another Pittsburgh based company Smiley Happy
Message 12 of 15
(840 Views)
Ernie, that's it! Aerotech motor with a Soloist controller. The supplied .NET code leaks memory. If memory serves, the leak occurs with the DIAG function, getting motor position. The Move function doesn't leak.
Try disabling the motor code and run your system somehow without the motor to see if yours is leaking.
It is a slick motor. Ours is set up for 3,600,000 counts for 18 turns (after our gearing) and it's spot on to the count.
Richard
Message 13 of 15
(830 Views)
I will look into it. Looking at a lot of things at the moment.
Message 14 of 15
(808 Views)
This is fixed in version 4.03.000 of the software.  See release note for issue "CTRL-16665".
This post is mostly to provide an answer to people who stumble on this thread.
Message 15 of 15
(711 Views)
