Memory leak in Convolution
The attached VI shows a memory leak in the Convolution routine in LabVIEW 8.6.1.  There is no memory leak in 8.2.1 - I have no other versions to test it on.
Cheers ~ Greg
Message 1 of 10
(6,660 Views)
Ouch!
Yes, something is terribly wrong in 8.6.1 with this function.
Message 2 of 10
(6,644 Views)
Hi Greg,
This behavior has been reported to R&D (#128859).  Note that the leak only happens when the size is set to size X.  Thank you for reporting this.
Best Regards,
Bryan H.
Message 3 of 10
(6,614 Views)
Looks like the problem is solved on 2009?
Message 4 of 10
(6,461 Views)
Yes, this issue has been fixed in LabVIEW-2009
Message 5 of 10
(6,435 Views)
You can always check the Bug Fix list to see if a particular CAR has been fixed.
-Chris M
Message 6 of 10
(6,399 Views)
So...I pretty much just have to live with this in 8.6?
Tim Elsey
Certified LabVIEW Architect
Message 7 of 10
(6,284 Views)
Accepted by GregSands
Hi Tim,
Since we are no longer developing for LabVIEW 8.6, this is going to be something you need to either workaround, or update to 2009.  The leak only occurs when you set the size to "Size X".  And, it has been fixed for 2009.
Cheers,
Marti C
Applications Engineer
NI Medical
Message 8 of 10
(6,260 Views)
Turns out a workaround wasn't very hard to come up with using Full instead of X.  Thanks
Tim Elsey
Message 9 of 10
(6,248 Views)
I just got bit by this bug in 8.5.1. :manmad:  It crashed LabVIEW a couple of times this morning before I could determine what was going on.
I'll use the workaround suggested.
Thanks!
Message 10 of 10
(5,732 Views)
