Measure of time elapsed
I've just started using LabView and I'm working on a project in which a sound file needs to be played once a microphone picks up a sound with a frequency above a certain level (I have a sound board right now that allows me to manually make these cues). I'm sure I'll have many more questions in the future, but for right now I was just wondering how I could measure how much time it takes for LabView to read the frequency and then play the file.
Message 1 of 13
(6,683 Views)
Accepted by rmhughes
You can get start time and end time by using Tick Count (ms) Function or Get Date/Time In Seconds Function.
Hope it helps!
Message 2 of 13
(6,670 Views)
I tried a similar setup on one of the templates but I got everything from 2.3 ms up to 109 ms. What are you using to break up the steps in that example?
Message 3 of 13
(6,640 Views)
Scratch the above question, I found it. When I try and play any .wav file it tells me that LabView does not support the sound format.
Message 4 of 13
(6,628 Views)
Sorry I'm being that annoying new guy in the forum who just posts questions as he thinks of them and doesn't bother doing work. I figured out the issue and everything seems to be working. I'm consistently getting readings of around 330 ms. Does that seem correct? Seemed a bit slow to me.
Also, out of curiousity, what is that item you're putting the final value into at the end of the process? I've just been using a numeric indicator.
Message Edited by rmhughes on 07-14-2009 02:40 PM
Message 5 of 13
(6,618 Views)
No worries 🙂
Check an example here for playing wave file.
also find attached files.
Message Edited by lvABC on 07-14-2009 03:42 PM
Message 6 of 13
(6,615 Views)
Thanks for all the help!
Message 7 of 13
(6,606 Views)
lvABC - I like your method of measuring time elapsed. How would this be done with Labview RT? The TickCount block only returns time in msec.
Message 8 of 13
(6,481 Views)
BenYL,
One quick way to get time output would be by using shift register.
Message 9 of 13
(6,470 Views)
Also- check out the elapsed time function on the timing pallate- Smiley Wink
"Should be" isn't "Is" -Jay
Message 10 of 13
(6,457 Views)
