Maximum XNET Sessions
Dan,
Was this issue ever resolved?  I'm encountering the same issue but I'm a complete newbie to XNET and I've no idea how to resolve the problem.
All the best.
Simon Carter
Certified LabVIEW Developer
@dhaugen92 wrote:
I am getting Error -1074384879 at XNET Create Session:2080003. Possible Reason(s): NI-XNET: (Hex 0xBFF63011) The maximum number of sessions was exceeded. Solution: Use fewer sessions.
What is the maximum number of sessions? Is closing a session with the XNET Clear.vi enough, or is there further steps to purge the session from memory that must be taken? This is for an application that is running 24/7 that creates and destroys sessions for every 'sequence' start, which is about once every three minutes. I am properly creating the sessions, and closing them at the end of every 'sequence' with the XNET Clear.vi, but am still getting this error.
Message 11 of 12
(1,329 Views)
@Sipic wrote:
Dan,
All the best.
Simon Carter
This issue was never resolved...
but
Ive since made a modification of my original program (without the CAN modification yet) for a completely separate CAN program (i.e. different bus signals), based on an OOP approach, and have NOT run into this error..... That is, the sessions are a property of the object.
There is, however, a possible end-all fix: if the error occurs, there is a VI in the XNET pallet under 'advanced' that is "Close XNET System", i think to programatically reset the XNET hardware... maybe this will help? I haven't tried it yet... Inside there is a VI not located on the XNET pallet called 'XNET Close', which I think might hold the key..
Dan Haugen
CLD Instructor
Message 12 of 12
(1,326 Views)
