Matlab in Labview
Hi everyone,
I've seen that there a bunch of topics concerning my problem but it seems none solve and answer my problem. My problem is the following:
I have a MPC in Matlab and I'd like to "translate" it to Labview. I thought about doing everything manually but in the end I realised it makes no sense, it's just to complex so I thought about transfering Matlab .m scripts to LabView using the script note. The problem is that I have multiple scripts, mutliple written external functions for exemple and I don't know how to interface it with my program.
Could you please explain me a bit how this interfacing between Matlab and Labview works? Could the "subscripts" be called as subVIs or could I maybe use flat sequence structure for example?
Thank you in advance!
(2,875 Views)
have you tried the math script option in LV. you can make sub vi which consists of  a mathscript where you write your subscript code. then you call these subvi's  in your main vi where you needed.
(2,870 Views)
