TDMS property NI_DiskCacheSize
Hello All,
I stumbled with  TDMS set property named NI_DiskCacheSize.
Can someone please tell me how to set 2Mb cache using this property?
what exact property value should I write to set cache size 2MB for TDMS file?
Help will be truly appreciated.
CLAD
Passionate for LabVIEW
(3,973 Views)
hi,
Please refer to the link for more details.
The default value is 2MB. If you would like to set to a new value, you need to calculate the exact value, for example, 5MB is 5 * 1024 * 1024 = 5242880 Bytes, so you need to set the property value to 5242880.
(3,971 Views)
Thanks for you concern.
I understood the calculation but dint find the link for reference.
Can you please put the link in your message??
CLAD
(3,958 Views)
(3,956 Views)
Accepted by topic author jatinpatel1489@gmail.com
Thanks very much
Its truly helpful.
CLAD
(3,936 Views)
jatinpatel1489@gmail.com wrote:
Thanks very much
Its truly helpful.
If it's really that helpful maybe you should give some kudos to the post that helped?  Or maybe even mark one of the other posts the solution instead of your post thanking them.
(3,920 Views)
