Match Regular Expression with 2 expressions
I'm trying to create an expression that will search a string for 1 of 2 patterns using the Match Regular Expression function in LabVIEW 2016. I want to pick out 12 characters from a string of some length in a line.
The patterns are as follows, where 'L' is a letter (A-Z) & 'N' is a number (0-9):
  1.        NNNNLNNNNNNN
  2.        LNNLLNNNNNNN
Is it possible to create an expression to do one of two things?
  1. Search for either pattern with an OR statement
  2. Search for the first four characters with an OR statement & the last eight with an AND; ie. (NNNN | LNNL) && LNNNNNNN
Examples of valid match:
  1. 0123A9876543
  2. A12AB9876543
Message 1 of 8
(7,102 Views)
For the first part, try this:
[0-9]{4,4}[A-Z][0-9]{7,7}|[A-Z][0-9]{2,2}[A-Z]{2,2}[0-9]{7,7}
To do it the second way:
([0-9]{4,4}|[A-Z][0-9]{2,2}[A-Z])[A-Z][0-9]{7,7}
Message 2 of 8
(7,056 Views)
Not an answer but I've found using the following website to be very helpful when working on any regular expressions.
https://regexr.com/
Message 3 of 8
(7,051 Views)
Your second regex that doesn't work will work if you remove the spaces right before and after the pipe character "|".
Ben64
Message 4 of 8
(7,046 Views)
Accepted by topic author SgtPeprLHCB
([0-9]{4}[A-Z]|[A-Z][0-9]{2}[A-Z]{2})[0-9]{7}
Message 5 of 8
(7,044 Views)
Thank you all! All great answers and all work. I went with the last answer since it was the shortest.
Kudos to Matt J. for the great webpage.
Message 6 of 8
(7,016 Views)
You can still replace [0-9] with \d to make it shorter!
Ben64
Message 7 of 8
(7,009 Views)
Besides the \d:
45 characters: ([0-9]{4}[A-Z]|[A-Z][0-9]{2}[A-Z]{2})[0-9]{7} ->
36 characters: (\d{4}[A-Z]|[A-Z]\d{2}[A-Z]{2})\d{7}
the last [A-Z] in the first capturing group can be brought outside the OR:
32 characters: (\d{4}|[A-Z]\d\d[A-Z])[A-Z]\d{7}
Obviously, less characters should not be a goal, but I think it's a bit clearer as well...
Message 8 of 8
(6,967 Views)
