Marker Position
I am currently looking to retrieve the position / number of a marker on a graph when I click it with my mouse,
I'm looking through the property node but I can not find one . I already made a similar method with a table and the node property "Arrayelements / position" giving a different value depending on the item clicked.
I'm on linux so the library is not available GetCursorPos (may be an equivalent ... but who knows if there's more simple).
If I find a solution in the meantime I'll let you know,
Mathieu
(3,002 Views)
what it is you call a marker? a point that belong to a plot? a cursor? a scale marker?
Epictetus
Antoine Chalons
(2,996 Views)
Accepted by M.athieu.
You could use what I did in this example and get the index of the data and index the array to get the data point that you are looking for.
http://forums.ni.com/t5/LabVIEW/How-to-add-a-cursor-to-a-waveform-graph-on-mouse-click/m-p/1583546/h...
I think that this is doing most of wat you are asking about except for getting the actual value.
Tim
GHSP
(2,994 Views)
Yes I was talking about Scale Markers !
Thank you Tim, It solves my problem I think, I'll use Coords/Vertical and refer a value to a marker !
(2,983 Views)
