Map lookup resizeable function
The index array function is resizeable. Could the same be done for the map lookup function?
Is there another elegant solution?
(1,987 Views)
You can use Loop instead, no option to read multiple Key value similar to index array.
(1,967 Views)
I agree that you should use a FOR loop.
In a well designed program, you would have an array of keys and want an array of values, no need for herding catsscalars!
(1,940 Views)
The only way to make a resizable function is to use an XNodes (LabVIEW Wiki).
Really hard, not the way to go...
(1,910 Views)
