Map bug: Cluster sizing issues when View Cluster As Icon unchecked (LV2020)
Hi all,
A map containing a cluster value exhibits strange layout and resizing issues on the BD when View Cluster As Icon is unchecked while the cluster is inside a map constant. Steps to reproduce:
  1. Create a map constant.
  2. Create a cluster constant and add a numeric and string control. Set its autosizing property to arrange vertically.
  3. Drag the cluster into the map constant.
  4. Right-click the cluster inside the map, then check View Cluster As Icon. It is displayed as an icon.
  5. Right-click the cluster inside the map, then uncheck View Cluster As Icon. The cluster becomes huge, the cluster items are drawn outside the cluster, and the cluster itself is in the lower right of the map container. Attempts to resize the cluster container are inverted compared to mouse movement, and can cause the cluster contents to disappear from view. There doesn't seem to be a way to recover from this state, even if View Cluster As Icon is checked again.
 Is this a known issue?
(2,392 Views)
Accepted by topic author Dataflow_G
Thanks for reporting this behavior. I have reproduced the problem with your instructions, and opened Bug #1106879 for our team to review.
All the best,
(2,298 Views)
Anything new on NI side? This bug is still present in LV2025 Q3.
(457 Views)
yes, it got a new id 3565416
Actor Framework
(395 Views)
