Manchester Decoder
If I am trying to implement a Manchester decoder on Labview , will it be enough to parse the binary array two elements at a time like this example:
01 10 01 10 01 01 10=
1 0 1 0 1 1 0
or should i generate a clock signal ?and how shall i proceed with it?
thanks
(4,419 Views)
As long as you are capturing the data at the correct rate, you do not need to worry about having the clocked completely synchonized (in time).  I have done Manchester Encoding of data and I just pulled off the two bits at a time and translated those.
(4,381 Views)
I am doing a RDS receiver using the attached block diagram , the modulation toolkit already offers a BPSK demod with its matched filter, and since I don't need to worry about the clock , all i have to do is Manchester decoder and differential decoder for now .
For the differential decoder , I found its transfer function H(z)=1-z^-1 , after manchester decoding and obtaining the bits how would I be able to decode?
does the FM-RDS toolkit make it easier for me to implement a RDS receiver? It only contains Generation and Analysis  but I'm not sure if it can be used to acquire RDS data
thank you
(4,363 Views)
