Managing custom error codes
I know we have the custom error codes editor, but this sort of data stays only within LabView folder (please correct if I got this wrong)
So if I want to keep track of my error codes around my project, how should I do it.
I manage custom error codes now simply through a VI that I use as a constant for errors (enum in, error out).
(3,805 Views)
I try to avoid custom error codes.  Usually I find a built-in error code that fits, then add in a possible cause.
See the attachment and http://forums.ni.com/t5/LabVIEW/Error-Rings/m-p/2337862
(3,787 Views)
Thanks for answer, but your solution does not solve my problem completely. Nice VIs though.
I use custom error usually for implemented DLLs that allways bring some new functionality, that is missing in LabView. Further, I use custom errors for standard programming in cases, that should never happen, like timeouts is queues and so on.
So basicly I have an library and this library should have its own custom error codes, that should not overlap within the project it is used in.
(3,764 Views)
Hi Bublina,
personally I just bundle the error listing file to my installer and/or standalone executable - this help file describes it. Not sure this solves your problem but I guess it might.
As I understand, you have the error handling part figured out, but I would still point you out to the SEH reference library (stands for Structured Error Handling). It has nice architecture as well as local and global error handling capabilities.
Jano
(3,716 Views)
