Main vi gets corrupted after changing subvi
I have a main vi with a subvi in several layers in the hierarchy. After changing the subvi, the main vi does not open anymore, therefor gets corrupted.
I have a backup. It happened also with the backup. What should I do ?
(2,845 Views)
Hai,
what you mean by corrupted? could you explain bit more what happened to main vi?
Mathan
Message Edited by mathan on 06-12-2008 05:11 AM
(2,836 Views)
hi
give more details like:
what is the vi doing?
what is the sub-vi functionality?
what changes did you make?
and anything more that might help us to understand the situation.
with the given info, we cannot frame any idea!
thanks
(2,835 Views)
The subvi is a functional global, where I added a case in the case structure.
After that you have to replace the enum constant for all the subvi calls in the main vi.
That is all I changed. After that the front panel of the main vi did not open anymore, and after a few seconds Labview(version 8.2.1) does not respond anymore.
(2,809 Views)
Hi Bart,
replace your enum with a type-def'd version. I wrote this Nugget to help with this exact question. Please review that Nugget and post follow-ups if you still have questions.
Ben
(2,803 Views)
Hello Ben,
Thanks for the advise. I followed it up, works fine now.
(2,774 Views)
