MSComDlg.ICommonDialog Problem with Windows 64-bit system
Hi all!
I try to use the common Windows dialog box for saving files. For this I'm using the ActiveX-class "MSComDlg.ICommonDialog" with the propertynode input "Filter" for the file types. It's the standard "SaveAsType.vi" (somewhere in the forum).
Everything works fine on a 32-bit Windows system. But when I run the code on a 64-bit system I can not save my file with the last file-extension in the box field. I always get a error-message: "The file name is invalid!" This happens only when the last box-element is selected. All other run normal.
So for example:
If may box array is
Matlab Files (*.mat)|*.mat
Text Files (*.txt)|*.txt
Excel Files (*.xls)|*.xls
and I select to save as *.xls and write as filename "Hello" in, I get on the 64-bit machine the error:
"Hello
The file name is invalid"
When I change the order of the box array *.xls will go but the new last element will produce this error.
So, can someone help me?
Kind regards,
llpauli
P.S. I'm using Win 7 64bit with labview 9 32bit. exe tested on win7 64 bit and win xp 32 bit.
Message 1 of 14
(16,745 Views)
Hi Ilpauli
can you pleas attach the SaveAsType.vi?
I'm unable to find it "somewhere in the forum"
Regards
DianaS
Message 2 of 14
(16,731 Views)
Hi
find attached the SaveAsType.vi!
So when you build the exe and call it in win 7 64bit it will work for all extensions fine expect for the last one in the list:  "Calibration Files".
Greetings 😉
Message 3 of 14
(16,725 Views)
Hi
I testet it here on Win 64bit but the ActiveX control is not supportet and so the Common Dialog Class not found.
I tried to register the comdlg32.ocx but this did also not work.
Which ocx are you using? Are you able to register it?
Can you attach it?
Regards
DianaS
Message 4 of 14
(16,709 Views)
On which Windows 64-bit System have you test it? XP, Vista or 7?
I haven't registered anything additional - it works with the standard setting from my Win7 installation. It's Win7 Professional. Could it be possible that it is working only with the professional version?
My comdlg32.ocx file from C:\Windows\SysWOW64 is attached.
Greetings
llpauli
Message 5 of 14
(16,702 Views)
comdlg32.ocx will be installed when you install the full version of LabView Runtime engine. It's in the Datasocket package.
llpauli
Message 6 of 14
(16,680 Views)
Hi
Im using win 7 64bit. I'm able to register the comdlg32.ocx now but can't use it in labview. There are always error messages.
Which one do you use (see screenshots)
Regards
DianaS
Message 7 of 14
(16,674 Views)
Hi!
I use the Library: "Microsoft Common Dialog Control 6.0 Version 1.2" and from there the object "CommonDialog (MSComDlg.CommonDialog.1)".
The last days it works fine, but now when I directly select the class I also get an error "97".
But my posted VI is still runing.
Regards
llpauli
Message 8 of 14
(16,665 Views)
Hi
yes error 97 this is also what I see.
Regards
DianaS
Message 9 of 14
(16,651 Views)
Here is one more example: http://zone.ni.com/devzone/cda/epd/p/id/818
It says:
NOTE: You must have one of the following programs installed to run this example:
  • Microsoft Office 2000 Developer Edition
  • Microsoft Visual Basic 6.0
  • Microsoft Visual Studio
Do you have one of them installed?
Regards
DianaS
Message 10 of 14
(16,649 Views)
