MSComDlg.ICommonDialog Problem with Windows 64-bit system
I assume the licence for the comdlg32.ocx is missing. So if you install (and licence) one of the
products named above it should work.
Regards
DianaS
Message 11 of 14
(2,778 Views)
I didn't had one of the three software installed. I installed now "Microsoft Visual Studio 2005" but I'm still getting Error 97.
Does it work at your PC?
Does also the last file-extension from the box-field works?
Greetings,
llpauli
Message 12 of 14
(2,766 Views)
Hi
I tested it here with another developement environment than labview and this works on windows 64bit.
So this may be a problem in Labview. I will tell R&D about it.
Meanwhile you should use windows 32bit.
Regards
DianaS
Message 13 of 14
(2,754 Views)
I know it's seven years late, but I just encountered this problem and found a fix. The "Array to Spreadsheet String" puts a carriage return/line feed at the end of the output string. Removing those two characters solved the problem.
Message 14 of 14
(1,877 Views)
