Lowercase to Uppercase and Uppercase to Lowercase
To quote Monty Python "And now for something completly different", how about using a lookup table with the UC and LC swapped in the LUT.
Message 21 of 38
(2,874 Views)
In Range and Coerce is just slightly slower than Is Equal? to (4 OR 5) by about 20%, so you could gain a teeny amount of speed there. They're both blazingly fast though, running 100000000 numbers through either of them took like a quarter of a second.
Message 22 of 38
(2,871 Views)
Or something even more differenter:
Message 23 of 38
(2,862 Views)
Why have the build array and byte array to string, just wire numeric to the case terminal.  It won't be as readable since it doesn't have ASCII mode but it does have Hex.
Message 24 of 38
(2,860 Views)
Even if you want the string for readability, the Rube Goldberg (built single element U8 array... Byte array to string) combo could be replaced by a simple typecast.
Message 25 of 38
(2,850 Views)
Yes, a LUT would be the way to go in deployed code. That's what I usually do.
(... But unless you want to create the LUT by hand, you still need one of our algorithms once :D)
Message 26 of 38
(2,844 Views)
@altenbach wrote:(It is a little-known fact that many string functions work perfectly on U8)
I did not know that! I want to change my answer to this 😛
=== Engineer Ambiguously ===
Message 27 of 38
(2,830 Views)
@paul_cardinale wrote:
OK.  But I'm usually more concerned with speed that with size and this is about 30 times faster than this:
True, but the LUT is still 4x faster. You can even create it on the fly and it will be constant folded without any speed penalty. 😄
Message 28 of 38
(2,806 Views)
I just wanted to make something intentionally Rube Goldberg, I didn't mean for it to be a particularly "good" solution 🙂
Message 29 of 38
(2,801 Views)
On a side note, the FOR loop can be parallelized, but it makes it actually slower for smaller strings. However, for gigantic strings is a way faster that the same code with a plain FOR loop (e.g. 1k characters: 10x slower,  1M characters: ~4x faster, 10M characters: ~6-8x faster) (this is on an old 16 core dual Xeon)
Message 30 of 38
(2,780 Views)
