12-13-2018 04:43 PM
Thank you everyone for your help. I got more than I thought.
12-14-2018 08:28 AM
So for 'always best performance' i take it we'll add an Array size on the U8 connected to a case with 1 parallell option and one normal, or will it be as fast if you use a parallell loop with N=1?
/Y
12-14-2018 11:23 AM
/Y
It probably won't be that easy to find a globally optimized solution that has the correct crossover point under all conditions. CPU architecture (cache sizes, number of cores, etc.) probably makes a difference. I would go with a plain loop because strings are typically short and that extra decision might even slow things down. 😄
12-19-2018 10:32 AM
Just thought I would give it a try.
12-19-2018 10:40 AM
You don't need the AND and the second Select function. If its input is TRUE, it means neither the To Uppercase nor the To Lowercase changed anything, which implies the bottom element is the same as the top element. It also means you don't need the lower Equal? check.
12-19-2018 10:46 AM
Yep, you are right. Nice job!
04-27-2019 01:38 PM - edited 04-27-2019 01:39 PM
Hello! Could you tell me what the name of the function is? Where can I find it?
04-27-2019 01:49 PM - edited 04-27-2019 01:50 PM
