Looping through Boolean Reference Cluster
I am trying to loop through a cluster of boolean control references and assign a value to them that comes in from another array. (In the image trying to replace the black circle on the left with the green circle on the right).
I tried following the instructions here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHdmCAG&l=en-US
which make sense but I can't figure out how to adapt it for my data type.
  1. Not sure what type of ClassID this is to put in the conditional
  2. Not sure what data type to specify for the "variant to data" to get the value out of the cluster item
Thanks for the help!
Message 1 of 13
(3,789 Views)
Try this
Message 2 of 13
(3,785 Views)
I appreciate the reply!
Sorry can you guide me with what you did here:
what did you place down on the block diagram first to get that boolean?
Also - what should I put in the case structure for Class ID?
thanks!
EDIT: I see now how to place the boolean item there, application control --> Class Specifier Constant
Message 3 of 13
(3,766 Views)
you get it from here
Message 4 of 13
(3,759 Views)
Also maybe use this for the case structure
Message 5 of 13
(3,749 Views)
got it, thanks.
What about the case selector for classID?
"Boolean" turns red.
Message 6 of 13
(3,746 Views)
Accepted by GOB34
If all the elements are of the same type it's easy to convert it to an array.
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 13
(3,740 Views)
Check my reply above. You replied before I figured out how to do it.
Message 8 of 13
(3,739 Views)
Yamaeda's way seems like a better way to do it.
Message 9 of 13
(3,737 Views)
Thanks for the suggestion.
Unfortunately all the data types are not the same, there is a mix.
Message 10 of 13
(3,727 Views)
