Looping through Boolean Reference Cluster
For the case structure I dropped a control (in this case a boolean control) on the front panel and then probed the ClassName to get the correct text to put in the selector field.You can do that for the other controls that you want to loop through.
Message 11 of 13
(557 Views)
@GOB34 wrote:
Thanks for the suggestion.
Unfortunately all the data types are not the same, there is a mix.
Then you can use Unbundle and Build array to group them up and handle each as required.
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 13
(548 Views)
Ahh good idea!
Message 13 of 13
(536 Views)
