Loop iteration without FoR loop...
I am designing a LabVIEW software for PID control algorithm. In the manual mode operation, due to the criticality of the system, the valve % should not suddenly jump to the new valve % value in one go, instead it should go at a rate of 1%/second. For example, if the current valve % is 30% and we want to set it to 50% then it must open the valve in steps of 1, that is, 31, 32, 33 and so on till 50%. How can I achieve this without using a 'for' loop? I am using different subVIs (e.g. to read/write P,I,D values, to read/write Setpoint etc) in the main VI program. Read/Write valve% value is also one of the subVIs. The attached images show the basic idea, but I am not able to do it properly (without using For loop). Can anyone help me out?
(3,908 Views)
I don't see a for loop in those pictures. If you attach the VI, we can actually help.
Certified LabVIEW Architect
(3,868 Views)
The vi in the images shown should work - but I don't know the context of how you're calling them. If you would share your code you would get a lot better quality help.
While I do not think a FOR loop is required for your application, nor even how a FOR loop would be beneficial (again, I've not seen your code so I don't know), I do wonder why the arbitrary requirement to do this without a FOR loop was implemented. It's usually better to use the tools that work than to add some arbitrary requirement.
(3,858 Views)
Isn't the point of the PID to limit the ramp rate, overshoot, etc?  Design your PID correctly and this should not be an issue.
(3,844 Views)
Anything you do with a For Loop you can do with a While Loop.  Both iterate, using an "index" labeled "i" in the lower left corner that increments by 1.  The While Loop stops when the Stop indicator is set to True, the For Loop stops on various "counting" conditions (depending on whether N is wired or not, or whether inputs are brought in through an Indexing Tunnel).  There are a few "specializations" that you can mimic with additional code:
  • A While Loop always executes what's inside at least once, while a For Loop might never execute what is inside (for example, if you bring an empty array into a Tunnel).
  • Hmm, can't think of other significant differences ...
(3,841 Views)
In the PID pallette there's also a rate limiter that will achieve this.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,832 Views)
Reading between the lines...
"PID Advanced.vi" has a manual input that allows us to set the output manually and will allow for bump-less transition to PID control.
Ben
(3,809 Views)
