Looks like a bug in Scan String for Tokens function...
Don't know if this has been reported earlier... But it looks like some sort of a buggy behavior and - evry time I find out something like this I prefer to share it with LV-community. So, LV6.1 FDS(French), W2K and Scan String for Tokens function. If all "operators" on input starts with a "%%" than this function simly do not work (with empty separators array). Adding any non-"%%"-started value in operators array solve the problem. There is an example to illustate what I mean...
(Heh.... Hope this is already fixed in LV7.0, but...)
(3,003 Views)
I have LV7 and I see the same bug. I can put a blank entry (space, then backspace)into then operators array and then I get good results.
- tbob
Inventor of the WORM Global
(3,003 Views)
Ok, so this bug is still there... Anyway, this one is not a simple one to find out, so no wonder that it rests unnoticed.
(3,003 Views)
I looked into this behavior and it has actually already been reported to R&D. They are looking into the cause etc. and it should be fixed for the next version of LabVIEW.
Evan
(3,003 Views)
