Thanx Bill for your kind response.
I will try above methods & let me check the results.
Mean time i have tried buffer position measurement instead of position mesurement method for encoder position through PXI-6602. Here i am getting all the counts. I am running both the vi (Buffered position & DIO handshake input), after 2-4 times running, i get error such as 10401/10409/10408. In DIO handshake vi, i m configuring 2 buffers, one for input & other for output. I have given group 0 to input buffer & group 1 to output buffer. For counter i have given buffer group as 6. Still i m facing the bufffer group problem. Sometimes i get error 10401 which says that the device is not from NI..or 10409 that is buffer is in use....
As i have switch
ed to this method, let me get idea why these problems are occuring.
Secondly if my first method (position measurement) works fine, i will be happy.
I am attaching cont handshake input vi(modified). Pl. ignore sub vi incase it prompts. Pl. let me know any suggestions/modifications required other than delay.
Thanx again for your response,
Best Regards,
Nirmal
