Looking for advice on having multiple channel cards
My program is currently working for using one channel card(multiplexer) which holds 20 total channels. But I need more channels and the instrument I'm using can hold up to 3 cards, however anytime I try changing it to read from the next card(basically using 2 cards in one program), it stops/won't continue the program. Anyone have ideas?
Thank you
(3,543 Views)
Please share your code. If using 2017 please save for previous version.
(3,532 Views)
1. Share some code.
2. What instrument and/or cards are you using?
(3,527 Views)
I attached some example code, I didn't put my whole program because it's not as easy to isolate the problem. I'm using Agilent 34970 and the corresponding functions. It's just the multiplexer cards that go with the instrument.
Hope this helps
(3,522 Views)
I tried a case structure with True being one card and false being the next, but still no luck
(3,452 Views)
It has been many many years since I wrote for one of those but I seem to remember something about the sub-addresses being not what I expected. Double check that documentation and your code.
Edit?
I may be thinking of another widget. After 40 years they are all a variation on a theme...
Spoiler
Which is the term a buddy of mine used to describe Jazz.
Ben
(3,444 Views)
