Logic Circuit Network
Hi, i have a very curious question about this particular implementation.. I don't understand how this is suppose to be implemented on labview or what it's meant to have.. I've tried braining it for hours and all i see are logic gates but i just can't imagine it inside labview.. Like is it possible to be even done in labview ..
(2,605 Views)
Hi dash,
Have you noticed this "Training resources" section in the header of the LAbVIEW board?
Yes, it's possible to implement the logic in LabVIEW.
To "imagine" those logic gates you might peek into the boolean functions palette!
(2,597 Views)
Get boolean expression for condition of warning signal then you can use comparison function together with boolean function to get the picture of question. The comparison is use to get result of binary value in the table and boolean function helps use to do the logic gate program.
(2,537 Views)
Hi dash,
@dash051107 wrote:
Practical advice:
  • Comparing float values with "<" or ">" is ok, but NEVER start to compare them using "="! Comparison (a) is valid, comparison (b) as well. But test (c) will by tricky to compare a real-world physical value for being exactly "20 l/s"!
  • There are some "OR" and some "and" in your description: these are boolean functions!
  • There are some ">", "<" and "=" - this will be comparison functions…
(2,518 Views)
