Lock Ni-Max
Message 1 of 10
(4,471 Views)
(Not sure why my first post is not there - seems as though explorer 9 was the culprit)
I am trying to lock Ni-Max so that my tasks and calibration information can not be changed.
Is there a way to do this? Or is there a way to handle this problem within labview?
Thanks for any suggestions!
mm
Message 2 of 10
(4,464 Views)
See this post.  Internet Explorer 9 and Firefox 4
Can you set up user access control on your Windows installation so that the user is not permitted to execute MAX?
Message 3 of 10
(4,453 Views)
We are using XP and the machine is logged in with a general user id so I am not aware of how to do that exactly.
I did look at there are several free apps we can use to lock the NIMAX exe file but I would think there would be a way to protect the data within one of the NI utils etc.
Message 4 of 10
(4,435 Views)
None that I know of. If anything there is a big sign over the door say welcome!
Go with the simple approach.
Ben
Message 5 of 10
(4,431 Views)
Use the NI system config API to save your configuration (to a read only file) and load the config at run-time.  Smiley Wink  keeps the users pretty honest
"Should be" isn't "Is" -Jay
Message 6 of 10
(4,430 Views)
And everything can be set in LabVIEW. No need at all to create tasks in MAX.
Message 7 of 10
(4,418 Views)
Great suggestions but can you expand on how to do that exactly?
1) When you say save the configuration - do I do that programmatically (Sys cfg pallet) or in NIMAX?
2) Once the config is what would I use to load it – do I just init using the Measurement I/O  /  System Config pallet?
Thanks!
M
Message 8 of 10
(4,416 Views)
"And everything can be set in LabVIEW. No need at all to create tasks in MAX."
Thats a good point - I could create my tasks but (long story short) we have a calibration group that likes to use NIMAX for calibration.
M
Message 9 of 10
(4,409 Views)
Add a good backup scheme to that plan then.
If you can't stop them from breaking it, at least you will be able to put it back together.
Ben
Message 10 of 10
(4,394 Views)
