ā04-14-2006 02:57 AM
ā04-14-2006 06:27 AM
Since LV does not know which copies of a local may need to be read some time in the future, the new value is written to ALL of the copies of the local.
So if you write to a idicator and thera are 9 local copies of that indicator, then the data is also written to the 9 "read local"s.
I hope I upderstood your Q.
Ben
ā04-14-2006 10:52 AM - edited ā04-14-2006 10:52 AM
Message Edited by Raghunathan on 04-14-2006 10:56 AM
ā04-14-2006 10:58 AM
You are correct.
Ben
ā04-18-2006 03:21 AM - edited ā04-18-2006 03:21 AM
Raghunathan wrote:
[...]Today I am happy that there is an elegant alternative as suggested with Local clusters and a single SR. Good. But what about the projects already commissioned ? To decide whether to recode them, I need to know this :
Now, after Bens answers, if you start to rewrite your code ....
If you use one SR (I prefer at least two, I like to keep the error cluster separate) another helping hint:
Use a type definition for your cluster, so in best case, you will only need to edit every subvi once.
Message Edited by Henrik Volkers on 04-18-2006 10:22 AM
ā04-18-2006 07:09 AM
