Launch external compiler before .exe build
I'm working on a project which uses some custom made .net assemblies.
I would like build the .net assemblies along with the LabView project VIs i.e. launch MsBuild before the LabView application is created and the Installer is packaged.
There's a chance to execute some custom code before the project itslef is built?
The only similar option I found is to 'Execute VI before build' (Pre/Post build actions page in .EXE build spec properties) but it sounds awful...
(1,093 Views)
That is the only way and it is awful...
(1,076 Views)
Thinking about it for a while I suppose there are other ways. I doubt they are more convenient though.
1) I suppose you can use the build API to build. Then you can program anything you want around that...
2) I suppose you can use LV's CLI interface, and use another 'authoring' tool (this could be the command line or a power script, I think) to call the CLI to start LV's build.
You probably just waste your time going those routes...
(1,068 Views)
Build API?
(1,049 Views)
Hi Michele,
Build API?
Yes, Build API:
(1,012 Views)
I see... too bad I cannot find examples... but it sounds promising.
(994 Views)
