Labview reports 'Excel Sort Data.vi' in Report Generation Toolkit is broken.
Accepted by STTAndy
It appears you're running into similar behavior documented in this KB:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019N7CSAU
The same troubleshooting steps, only applied to the VI in question here, should fix your VI.
Message 11 of 17
(5,776 Views)
KCS articles for the win.
I couldn't search for this article when troubleshooting. Please add 'Excel Sort Data.vi' as an example vi that breaks in the article as most people on the forums have error codes pointing towards this VI.
Message 12 of 17
(5,774 Views)
PERFECT!  THAT WORKED!  THANK YOU BOKNOWS!  KUDOS!
1)
2)
3)
Message 13 of 17
(5,770 Views)
It seems Bo really does know. Thank you I have marked it as the solution and another lesson learnt.
I did not know Office had updated, microsoft doing things quietly in the background again, I don't feel I am working alone here Smiley LOL
Message 14 of 17
(5,755 Views)
I just updated the Knowledge Base article Report Generation Toolkit VIs Broken After Updating Office 365 to illustrate the recent changes in Office 365 as described above. Thanks to BoKnows and Tom for noticing!
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 15 of 17
(5,751 Views)
Great thread...  It fixed my problem as well. MS Office update is what caused issue on my end.
Message 16 of 17
(5,563 Views)
Just in case more run into this issue: I just updated the Knowledgebase article to reflect all changed needed to fix "Excel Sort Data.vi": LabVIEW Report Generation Toolkit VIs Broken
Please note that there are also repair steps available for 'Excel_Save_Workbook.vi': VI Is Broken When Using Excel_Save_Workbook.vi
CLADMSD
Message 17 of 17
(5,083 Views)
