Labview is very slow
Hi i am working on labview 7.1.I am building a VI of big
size(50MB).when i am editing the VI it is very very slow and it is
taking minutes of time for every action.please suggest me are there
any settings to change to avoid this problem.
Message 1 of 12
(5,794 Views)
Hi 4303,
have you read the development guidelines? One of the main points is: "Avoid vi's bigger than your screen size!"
Why is your vi so big? Do you have big arrays set to 'default value'?
Compare this to a C-compiler (or whatever): create a 50MB project and do some recompiling after EVERY change you make... This would be slow too...
Message 2 of 12
(5,779 Views)
Same problem for VIs of size >20MB with the same version of LV.
I think our PCs are dead slow... ! Smiley Wink
What configuration do U ve ?
Mine is P4, 2.80 GHz, 1 GB RAM. I think this is not enough for LV.
When we asked NI, they told us for LV 7.1 & LV 8.20, even 512 MB RAM is enough, for LV 8.0 only 1 GB RAM is required.
Can experts ve a say on this issue ?!
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 12
(5,779 Views)
HI parthabe,
memory requirement for developing environment has nothing to do with size of your vi's!
As said before: changes to your vi will force LabView to do a recompiling. Compiling includes more than just 'translation': sanity/error checks, optimizations steps and much more.
So: read the developement guidelines before creating big vi's or projects!
Message 4 of 12
(5,772 Views)
for both of you: here you find the Development guidelines checklist!
Message 5 of 12
(5,757 Views)
Hi Gerdw,
I think I know 1/10th of the LV Style Guidelines, if not all of them.
But the problem is in 2 of my VIs in my application, they require extrordinary insertion, replacement & deletion of large chunk of data. say, constantly 16xN. This is because the user will choose digital signals of 0s & 1s for the 16 channels for N no of samples (columns) he wants & then in turn frame the test conditions for a particular test of an IC.
Since the user needs to insert, replace or delete whenever he wants, I need to keep an array of a predeclared size of 4Kx4K.
I think this eats u a lot of disc space indeed as you ve mentioned in your earlier post.
I cant think of a much better way to accomplish this task. Seperate file for each chunk of digital signal values will become another big problem with respect to insertion, replacement & deletion as pewr the serial nos, since this wil require to reneme or delete the file itself.
I hope this clearly explains you of my situation.
Message 6 of 12
(5,748 Views)
Hi parthabe,
do you use booleans or U16 integers?
Instead of 16 booleans you can use a binary formatted U16. This will save you 14/16 = 87.5% of memory usage (U16 needs 2 bytes, 16 booleans take 16 bytes)!
Message 7 of 12
(5,743 Views)
Hi GerdW,
Can you follow this procedure ? Open a VI & make a 2-D Integer Array constant of U8.
Put the indices to 4096x4096 & fill with 0. This is what I had assigned 0s upto & kept inside those 2 VIs.
Now save the VI & see its size, a whopping 16 MB right ?
Try t out with Binary format for the Integer Array. Then also it is the same size. Not even a slight diff, right ?
Or, don't I understand what you meant to do... ?! Smiley Wink
For 2-D Integer Array of U16 of the above size, the VI size is a whopping 32 MB for both the cases, viz, normal integer & binary integer.
Can you explain a bit more to me about how to really reduce the VI size by reducing this 2-D Integer Array size ?
I reall ydon't know... Smiley Sad
Message 8 of 12
(5,734 Views)
Use a initialize array function!
That way the data is not stored inside the VI!
Ton
My LabVIEW Ideas
Message 9 of 12
(5,722 Views)
Hi parthabe,
you said: '16 channels of 0/1'.
When you store this information as array of boolean you need 1 byte per boolean = 16 bytes for 16 channels.
But: you can use just one U16 to store the same information - and it only needs 2 bytes. 87.5% less memory consumption.
And as noted by TonP: use the 'Initialize Array' function...
One more question: why do you need a 4k×4k array when you only have 16 channels?
Message Edited by GerdW on 04-19-2007 09:13 AM
Message 10 of 12
(5,675 Views)
