el 03-11-2008 03:43 AM
I have Zebra TLP3844-Z on USB and with easy text report I always get error "Invalid printer name" even with the Default printer name found with Query available printers.
I want to print barcode label define with zpl .txt file and DOS print command to printer on LPT port work great, but I must use 2 printers and target PC haven’t any LPT port.
el 03-12-2008 10:58 AM
el 03-13-2008 03:03 AM
Problem is that I must send only data, nothing elese, no margins, page format... nothing and these is a problem, how to do that in Windows. With DOS Print file command these can be done, but only if printer is on LPT1.
el 03-13-2008 09:23 PM
el 01-07-2009 11:21 PM
Hi JB,
Will you be able to share your driver and use with a Citizen printer.
I am to use a CBM1000 USB printer. Thank you.
el 01-08-2009 02:57 AM
Hi Gelb,
There is a lot of work and knowledge behind this driver and therefore I'm not willing to share it on this forum. Please give me your email so I can contact you privately.
Have a nice day
PS : Gelb --> do you speak german ?
el 01-08-2009 04:13 AM
Hi JB,
Ja ich spreche ein bischen deutsch aber nicht gut. Spricht du aus?
Mine email is gelbvonn@yahoo.com
Thank you for sharing your knowledge.
Cheers,
JB
el 01-08-2009 06:01 AM
el 09-01-2009 06:58 PM
Do you make this Driver? is ease to do it in serial or parallel port but in my case I need it in USB because I have 3 test station with two printers each.
Any Idea?
thank you
el 09-02-2009 01:13 AM
lmontoya wrote:Do you make this Driver? is ease to do it in serial or parallel port but in my case I need it in USB because I have 3 test station with two printers each.
Any Idea?
thank you
Which driver of the about 5 discussed in this thread do you mean?
Rolf Kalbermatter
