Labview communicate with Arduino+XBEE
Hi everyone,
i want to send a signal from arduino to LabView via two xbee.. what is the best code for arduino and labview to have a good transmission and acquisition signal ??
Message 1 of 8
(5,251 Views)
Hi Meth12,
Are you familiar with the LabVIEW arduino toolkit? This is a link to the web page for this toolkit.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/212478
The following two links show how to get started with Arduino communication and a simple example:
https://forums.ni.com/t5/LabVIEW-Interface-for-Arduino/LabVIEW-Interface-for-Arduino-Setup-Procedure...
https://forums.ni.com/t5/LabVIEW-Interface-for-Arduino/Arduino-Example-Simple-LED/ta-p/3522414
I would also recomend looking at this introduction to using XBEE with LabVIEW:
https://forums.ni.com/t5/LabVIEW-Interface-for-Arduino/BEGINNER-connection-Labview-Xbee/td-p/3416872
It would also be helpful to know exactly what you are trying to do. What is your application and your final goal? A diagram of the system components and communication between them would be helpful.
-Mitchell | NI
Message 2 of 8
(5,146 Views)
Hi mfaltin,
My project is about transmission of single channel EEG based on arduino boad for ADC and xbee. I'am trying to acquire the signal comes from pin A0, transmitted by xbee and display it on labview.
Can you enlighten me Sir on how it is possible to send and display a good EEG signal?
Message 3 of 8
(5,143 Views)
Hi meth12,
EEG's are not my area of expertise so I will not be able to help you with the technical knowledge of how to collect an EEG signal. If you want to communicate between the Arduino and LabVIEW, I recommend looking through the documentation of the LabVIEW-Arduino toolkit or trying one of the examples I provided.
Have you gotten an example program working?
Message 4 of 8
(5,126 Views)
hi mfaltin,
sorry for the late i was so busy. yes i do have a program working... honestly, what i'am looking for is an arduino code to send and receive signal from arduino board to display it in LabVIEW.
Message 5 of 8
(5,104 Views)
How do you intend to transfer the data between the Arduino and LabVIEW?
Message 6 of 8
(5,084 Views)
By usb cable .. i attached arduino to computer via usb cable .. in LabVIEW i read from the COM of arduino, set the same baude rate and run my program.
Now i want to send data via xbees modules. What is the code to transmit and receive the signal ??
Message 7 of 8
(5,080 Views)
Hi meth12,
You will need to develope the code on your own. There is no standard shipping example for xbee communication. I recommend looking at the examples and tutorials I sent you and also posting your question in the LabVIEW Interface for Arduino Discussions linked below.
https://forums.ni.com/t5/LabVIEW-Interface-for-Arduino/ct-p/7008
Message 8 of 8
(5,066 Views)
