05-26-2010 12:36 AM
Hi, I'm trying to read my joystick using the labview but it can not read anything, although I am changing controls, The readings of the values are frozen
I am check with windows the joystick an it is recognized correctly by the PC !!!, also using the Control Panel and open up the Game Controllers options dialog I can test it and it is OK.
What is the problem? Why the labview can not red the joystick?
I used this VI to test the joystick
05-26-2010 01:11 AM
Been a long time since I used a joystick.
Perhaps you need to set another instance ID (the '0'), maybe just test it with values op to 10 or something.
Ton
05-26-2010 02:48 AM
Hi!
For my USB joystick I'm using a different approach, as described here:
http://decibel.ni.com/content/docs/DOC-3466
Marco
