Labview can not read my joystick
Hi, I'm trying to read my joystick using the labview but it can not read anything, although I am changing controls, The readings of the values are frozen
I am check with windows the joystick an it is recognized correctly by the PC !!!, also using the Control Panel and open up the Game Controllers options dialog  I can test it and it is OK.
What is the problem? Why the labview can not red the joystick?
I used this VI to test the joystick
(2,860 Views)
Been a long time since I used a joystick.
Perhaps you need to set another instance ID (the '0'), maybe just test it with values op to 10 or something.
Ton
My LabVIEW Ideas
(2,849 Views)
Hi!
For my USB joystick I'm using a different approach, as described here:
http://decibel.ni.com/content/docs/DOC-3466
Marco
(2,833 Views)
