Labview and Raspberry
Hello everyone,
I‘m using a cam from Raspberry pi. The image must be captured with LabVIEW. I read in many topics, that there is no compatibility between Raspberry and LabVIEW . Do you know any solution for this ?
In order to capture the image, which toolkits do I need ? The Vision module ?
Greetings
Ayman
(1,881 Views)
What version of LabVIEW are you using? If you are using the community edition (the free one for non-commercial use) you should have the LINX/hobbyist toolkit already, which will allow you to run LabVIEW on a Raspberry Pi. If not, you should download and install the Linx toolkit
There is more information on the LabVIEW Makerhub website on how to get started with it.
As far as the camera goes - can you give us some more information on the camera you are using?
(1,868 Views)
First of all thank you for your reply. I use LabVIEW 2020 professional development System.
The Camera I use is Raspberry Pi® Camera Module V2 NoIR 8MP CMOS RGB. The camera should be connected to raspberry Pi.
(1,836 Views)
