USB 6009 Win 10
Which Versions of VISA and DAQmx are necessary to run the USB 6009 with LABVIEW 2011 SP 1 running Win 10/64 bit?
Tnx for any info.
(1,550 Views)
Hi wafy,
@wafy wrote:
Run the USB 6009 with LABVIEW 2011 SP 1 running Win 10/64 bit?
With Win10 you should use a more recent version of LabVIEW!
For your USB6009 you need a DAQmx version compatible with your LabVIEW version: search for "LabVIEW DAQmx compatibility" to get an overview from NI.
(1,523 Views)
Hi GerdW,
thanks for the fast answer. I will look for a suitable DAQmx Version.
WaFy
(1,502 Views)
Search the Web for "DAQmx and LabVIEW Compatibility".  Note that LabVIEW 2011 is really pretty old -- if you don't have the installation disks, you might be in trouble ...
(1,475 Views)
Hi Bob,
thanks for the answer. DAQmx 15.5 works fine.
Best regards
(1,448 Views)
