le 11-11-2019 08:43 PM
Hi
I would like to ask why do I have Error 59 on my program. The data acquisition module is connected to my laptop when I used the adam utility software. However, when I tried to use labview, error 59 occurs and no readings are collected. Where did I make a mistake?
Help is greatly appreciated, thank you!
2019-11-12 (2).png is an image of my block diagram.
2019-11-12 (3).png is an image of my front panel.
2019-11-12 (4).PNG is an image showing the data acquisition is connected to by laptop via a ethernet cable.
Résolu ! Accéder à la solution.
le 11-11-2019 09:13 PM
Error 59 is that the network is down.
Your one picture with the working programming shows you are communicating with a device at 10.0.0.11.
Your picture with the non-working VI shows an IP address of 169.254.21.119.
Do you think that might the cause of your problem?
le 11-11-2019 10:35 PM
Hi
thank you for your help, greatly appreciated! yeah, it is because of my ip address.
