Labview NI-FPGA, generating N pulses at high frequency (1-5 MHz)
 Terry_ALE  &
Thank you for your answer. NI FPGA derived clock gives the capacity to produce 800 mhz, how is this possible. Is there a possibility to create this frequency?
Another thing I'm wondering is that if I divide the loop into two, I get 10 MHz output. If I divide it by 3, I get an output of 6.666 MHz. Is there a way to elaborate on this?
I want to produce more detailed frequencies between 10KHz and 5MHz. For example, if I want to produce 4.5Mhz-4.4Mhz, what can I do?
Message 21 of 25
(1,197 Views)
Have you made a software version of what you want to generate?
Sorry if you have posted it already.
This could help greatly.
Regarding clocks, the single cycle timed loop is not configurable at runtime so it must remain fixed. Variations have to happen via logic as mentioned earlier.
ALE Consultants
Message 22 of 25
(1,194 Views)
This issue has been resolved. Thanks for all the help.
Message 23 of 25
(1,178 Views)
Sorry, the code is attached.I thought it wasn't necessary.What I want to do here is to use DIO pins on both FPGA and Myrio.
Message 24 of 25
(1,132 Views)
In NI-FPGA, there is 40MH speed. One loop will take one tick. SO wait for 4 tick that could generate 10Mhz pulls.
Message 25 of 25
(1,081 Views)
