Labview Download Error
Hello, I want to download Labview but I get the following error. I leave the screenshot of the error on the attachment. I turned off my firewall. I've done the updates, but I'm getting the same error. I could not find the reason. I would be glad if you help 🙂
ERROR:
" There was a problem executing your request. The network operation exceeded the user specified or system time limit. (Operation too slow.Less than 30 bytes/sec transferred tha last 60 seconds) Please check yout internet connection and try again."
(4,594 Views)
ERROR:
When did you try this?  Sundays are generally bad for downloading stuff because it's highly likely that web site maintenance is going on.
Bill
CLD
(Mid-Level minion.)
(4,556 Views)
same issue here while trying to download LabVIEW 2021 SP1 in 32 bits.
I tried several times during different days, hours of the day with same result.
Can anyone at NI help with that issue?
(4,052 Views)
Hi jeanlongchamps,
Just want to check if your firewall is enabled and probably if it is blocking your download.
Try to disable your firewall and check if that works.
Also, just want to check if your PC has met the minimum required specs to download/install LabVIEW 2021 SP1 in 32 bits.
(3,717 Views)
