How to connect NI-8452 to AD2S1210SDZ with SPI
I Have some problem.
When I connected NI-8452 and AD2S1210SDZ through SPI, [SCLK, MOSI, MISO] were connected as same position at AD2S1210SDZ and in AD2S1210SDZ, CS, WR, RD were connected to GND.
And i used example [General SPI Read]
In source, [Number of byte to Read] was 8, [EEPROM Data Address] was 0, [Data Address Width] was 2byte, [Clock Rate in kHz] was 1000.
I want that signal is 0 to 255
However, the signal only outputs 0 or 255 per 30 degrees
So, The things i want are
Is it possible Connecting NI-8452 and AD2S1210SDZ through SPI?
Is the way using example was incorrect? If i did, how to use the example correctly
Is the example was incorrect?
If you don't have enough information to give advice, please mention it.
(1,695 Views)
Perhaps you might want to check if the AD2S1210SDZ allows SPI communication with the ADI Technical Support Engineers and allow if such communication is possible using LabVIEW. Perhaps they might have a better answer on how to use their HW with other third party softwares.
Honestly, there is not much information regarding AD2S1210SDZ with SPI communication besides the links I found below.
https://forum.arduino.cc/t/spi-communication-to-a-ad2s1210-eval-card-with-arduino-mkr-wifi1010/95804...
https://ez.analog.com/data_converters/precision_adcs/f/q-a/24092/problem-with-ad2s1210sdz-board-thro...
(1,605 Views)
