Labview Certification
Hi All,
I am interested in Labview Certification. Can some one help me out regarding the references that i should go through for this.
I have gone through NI Fundamental exams and also cleared them.
Also i have seen the Basics I & II tutorials from NI.
But will that be sufficient??
Your guidance will be highly appreciated!!
Message 1 of 10
(5,521 Views)
Hi Harish,
Your first step would be to take CLAD Certified LabVIEW Assocoiate Developer) exam
The preperation that you mention you have done, should be enough to take CLAD. Provided, that you also have enough 'hands on' experience
These links will also help you prepare for CLAD
If you are in India, contact your nearest NI office and they should be able to explain the process of applying for CLAD
Any doubts, do get back
Dev
Message Edited by devchander on 09-11-2006 03:27 AM
Message 2 of 10
(5,520 Views)
Hi Dev,
Thanks for your prompt reply. Your link will definitely give me an insight of the minute details for my preparation.
I have been working on Labview for quite some time now. But much of my work had been in Labview 7.1.
I have not used Labview 8.0 much. Is this going to hamper the certification process in any ways?
Currently i m in Mumbai, India.
-Harish
Message 3 of 10
(5,514 Views)
For CLAD, its not much of a bother, I guess.
But for CLD, its always safer to be well versed in the current version of LabVIEW.
Contact your regional NI people for more info
Dev
Message 4 of 10
(5,506 Views)
Hi Harish,
I have several colleagues that had the basics I and II. They all made the online test and also made screen-shots (print screen) to go over the questions after the online test. Nobody has passed the real test yet as the questions were pretty different to the online questions. I haven't prepared yet to take the CLAD, but will for the future. I think it's a good idea getting the print screens, so you can see how the vis work. The online test doesn't tell you which answers have been wrong. So it's good to check that by your self.
Hope that helps a little.
The German Guy.
The German Guy
Message 5 of 10
(5,482 Views)
RE: Familiarity with the current version of LV
Part of the certification process checks that you are up to speed on the current version. Since LV 8.20 is newly released, you should check with the testing center to find out version of LV they have installed on the machines.
If you do not have the most couurent version, you could try down-loading the trial version before you take the exam.
Getting familiar with the new version will help because the location of functions have moved since LV 7.X  and you do NOT want to be learning were to find the new locations durring the test.
Ben
(Certified LabVIEW Architect)
Message Edited by Ben on 09-11-2006 07:40 AM
Message 6 of 10
(5,481 Views)
When I took CLAD, it was a written test and not online.
so, check out if it is still the same in India.
But for CLD, you will certainly have to use the current version of LabVIEW
Message 7 of 10
(5,471 Views)
CLAD is written, but you can practice online here: http://www.ni.com/training/labview_exam.htm.
As soon as you pass the online exam, it will not let you take it any more. We have made the screen shots from there.
The German Guy
Message 8 of 10
(5,465 Views)
Can you send me the screen shots, or the link where i can have access to them.
That would be of great help.
My email id is: h_kumar02@yahoo.co.in
Thanks in advance!!
- Harish Kumar
Message 9 of 10
(5,398 Views)
Harish,
my colleague zipped the file. As it just contains all screenshots as tiff-files, it will be more than 200MB when unzipped.
The German Guy
The German Guy
Message 10 of 10
(5,376 Views)
