Labview 8.6.1 RT crashes while developing
Hallo, I am using LV 8.6.1 with real time extension.
While developing, sometimes occurs that LV environment crashes without any error message.
It simply closes all.
It happens when, for example, i am trying to wire some variables or create some new local variable.
I enclose two lvfailurelogs of these crashes.
Has someone any idea why this happens?
Thank you.
Marco
Message 1 of 13
(4,030 Views)
Hi Marco,
does this crash happen randomicly or is it systematic? Does it happen also on different PCs?
Is your block diagram big, with a lot of objects and subVIs? In some cases, this was connected to similar error logs.
Sometimes, what suggested in this forum have helped: let me know if it helps also in your case!
Bye!
Licia
Message 2 of 13
(3,986 Views)
Accepted by Marco_Ge
hallo
thanks for your reply
no the project is not so big!
the crash occurred in a complete random way.
it was strange because it happened on a new planform (new pc with new labview 861 rt installed and no other applications)
but yesterday i did a mass compile... it seems that now it is working without crashes!
i will use it again the next days and will let you know
thanks a lot!!
good all to yoU
marco
Message 3 of 13
(3,973 Views)
Hi Marco,
glad to hear that the problem seems solved right now!
Keep the situation under control and let us know!
Bye!
Licia
Message 4 of 13
(3,969 Views)
So, from which version of LV RT did you transfer the code to LV RT 8.6.1?
Licia, is this a known issue with LV RT 8.6.1? Can you confirm this?
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 13
(3,967 Views)
Hi Partha,
actually there is no similar known issue for LabVIEW RT 8.6.1.
In any case, Marco's problem should be more investigated and reproduced to understand possible similarities.
Licia
Message 6 of 13
(3,961 Views)
hi all,
the installed LV 861 + RT package was all included in the developer suite folder provided from NI to alliance members
the project was created by zero on this new platform, not imported
the laptop is a dell latitude e5500 brand new + XP Pro sp3
thanks!!
good work
marco
Message 7 of 13
(3,958 Views)
Why did you Mass Cmpile then? Any particular reason? OR, just it was one of those trial & error steps you did to debug your project?
Why I m asking all these is because normally Mass Compile is done on VIs or the folder(s) containing the VIs, inherited from a lower version of LV.
Please see the attached screenshsots.
Message 8 of 13
(3,950 Views)
i did a mass compile of my project folder only because i've experienced that sometimes it helps...
this even if you are using the same version vis!
is it possible that some vis in install package were not well aligned?
did you see something inside the attached failure logs?
Marco
Message 9 of 13
(3,941 Views)
I saw the error logs, but cant understand much.
I saw something related to User32 DLL of Windows. Is that your RT ptoj has any external DLL to be called by LV? If so, did you check the compatibility of that DLL with LVRT?
I recently encountered with a problem of this sort...
Message 10 of 13
(3,929 Views)
