AIM ARINC (AMC-429) Block Data Read
I have the above card configured to receive ARINC label data. I want to be able to read a block of data from predefined array of labels.
I have downloaded the driver package from AIM website and managed to read data from one label at a time, this is time consuming and does not do the job. I was wondering if any of you has used the memory functions in the driver to read a block of date. The manuals don't seem to give much information on the same. I am looking at the following commands but can't figure out how to calculate the offset required for the second function.
Api429CmdRxGetBufAddress()
Api429ReadBlockMemData()
Please help. I am sure someone out there would have used this. A CVI /C / C++ or VB implementation would do.
thanks and regards,
aCe
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,285 Views)
This fourm is to support users using LabVIEW. I believe you are intented to use CVI/C/C++/VB? Please post your question on the relevant forums.
Mark M.
National Instruments UK & Ireland
(3,266 Views)
Mark
Sorry, what I meant was an implementation in any of those languages will do which I can convert to Labview. So my implementation will be in Labview.
thanks and regards,
aCe
(3,251 Views)
